I'm trying to add a new 4TB disk to my FreeNAS server.  I partitioned it with gpart:
and newfs'd it, like this for all the three partitions:
But when I click on the "Import Volume" button under Storage in GUI, it says "Sorry, an error occurred". Here's the extended traceback.
I have a similarly partitioned disk (but 3TB, not 4TB ) which is mounted correctly:
Rebooting didn't help, but I can mount the partitions from the 4TB disk by hand. But I don't want to do that because (I guess) they wouldn't be persistent across reboots.
FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty), on AMD Athlon(tm) II Neo N36L Dual-Core Processor.
Any suggestions as to what could be wrong? I can see that the "Exception Value" is '/dev/ada1p5', but I have no clue what it is about. All partitions on ada1 are mounted without issues and also shared via CIFS.
Thanks,
Saurav.
[saurav@freenas /mnt]$ gpart show ada2
=>        34  7814037101  ada2  GPT  (3.7T)
          34          94        - free -  (47k)
        128    4194304    1  freebsd-swap  (2.0G)
    4194432  2147483648    2  freebsd-ufs  (1.0T)
  2151678080  4294967296    3  freebsd-ufs  (2.0T)
  6446645376  1367343104    4  freebsd-ufs  (652G)
  7813988480      48655        - free -  (23M)
sudo newfs -L Data -O 2 -U /dev/ada2p4
Request Method: GET Request URL: http://192.168.1.144/storage/import/ Software Version: FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty) Exception Type: KeyError Exception Value: '/dev/ada1p5' Exception Location: /usr/local/www/freenasUI/../freenasUI/storage/forms.py in _populate_disk_choices, line 550 Server time: Mon, 23 Sep 2013 17:15:49 +0530 Traceback Environment: Software Version: FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty) Request Method: GET Request URL: http://192.168.1.144/storage/import/ Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 105. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 166. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 20. return view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/storage/views.py" in volimport 254. form = forms.VolumeImportForm() File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in __init__ 530. self.fields['volume_disks'].choices = self._populate_disk_choices() File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in _populate_disk_choices 550. del _parts[name] Exception Type: KeyError at /storage/import/ Exception Value: '/dev/ada1p5' Request information GET No GET data POST No POST data FILES No FILES data COOKIES Variable Value fntreeSaveSelectedCookie 'root%2F61%2F68%2F82' fntreeSaveStateCookie 'root%2Croot%2F61%2Croot%2F61%2F68%2Croot%2F20%2F43%2Croot%2F87%2F91%2Croot%2F101%2F133%2F134' META Variable Value wsgi.multiprocess False REDIRECT_STATUS '200' SERVER_SOFTWARE 'nginx/1.2.2' SCRIPT_NAME u'' REQUEST_METHOD 'GET' PATH_INFO u'/storage/import/' SERVER_PROTOCOL 'HTTP/1.1' QUERY_STRING '' CONTENT_LENGTH '' HTTP_USER_AGENT 'Mozilla/5.0 (X11; Ubuntu; Linux i686; rv:24.0) Gecko/20100101 Firefox/24.0' HTTP_CONNECTION 'keep-alive' fntreeSaveStateCookie=root%2Croot%2F61%2Croot%2F61%2F68%2Croot%2F20%2F43%2Croot%2F87%2F91%2Croot%2F101%2F133%2F134; fntreeSaveSelectedCookie=root%2F61%2F68%2F82' SERVER_NAME 'localhost' REMOTE_PORT '46496' wsgi.url_scheme 'http' SERVER_PORT '80' DOCUMENT_ROOT '/usr/local/etc/nginx/html' HTTP_X_REQUESTED_WITH 'XMLHttpRequest' DOCUMENT_URI '/storage/import/' wsgi.input <flup.server.fcgi_base.InputStream object at 0x80f35a850> HTTP_DNT '1' wsgi.multithread True HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded' REQUEST_URI '/storage/import/' HTTP_ACCEPT 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8' wsgi.version (1, 0) GATEWAY_INTERFACE 'CGI/1.1' wsgi.run_once False wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x808a7fe90> REMOTE_ADDR '192.168.1.144' HTTP_ACCEPT_LANGUAGE 'en-US,en;q=0.5' CONTENT_TYPE 'application/x-www-form-urlencoded' HTTP_ACCEPT_ENCODING 'gzip, deflate'
[saurav@freenas /mnt]$ gpart show ada1
=>        34  5860533101  ada1  GPT  (2.7T)
    4194432  3145728000    2  freebsd-ufs  (1.5T)
  3149922432  1048576000    3  freebsd-ufs  (500G)
  4198498432  1048576000    4  freebsd-ufs  (500G)
  5247074432  613458703    5  freebsd-ufs  (292G)
Thanks,
Saurav.
