cant get network contact
Havard79
i can reach the server on admin login via web but when i seach for it in network i get a error messagages like server uses to log time to respond or unabel to accesses location. what is wrong here?
You use a browser to connect to the web UI of the server, but shares make parts of the storage space within the server available to the network. So the step you have missed is creating the share on the server. Before you do that though, you have to create a pool, then a dataset in that pool and then associate a share with the dataset. The FreeNAS User Guide is your friend.
Chris Moore
Is this a new configuration or something that was working and now it is not?
Also, please provide the required information regarding your system, with this as a guide :
Updated Forum Rules 12/5/18
https://forums.freenas.org/index.php?threads/updated-forum-rules-12-5-18.45124/
Havard79
it's a new installation and and i'm used to the old ui.
i created a pool and every thing see attached photo
Have you set up any shares? Can you select Sharing from the sidebar and provide a screenshot of any shares you have created?
Havard79
i have done that to samba and unix
The users dataset and child datasets are missing in the Pools view. This probably is the cause of the network connection failing.
Havard79
added users dataset in the pool but it didnt help at all added child to
That's not going to work as you've added users under iocage. You need to relocate the dataset users under the disk1 pool. As you currently have it, the path is /mnt/disk1/iocage/users which is a mismatch to what you currently have for each of the shares. Note: Unless you're directed to, you should not be creating any child datasets under the iocage dataset. Let the system manage that area.
