Cant even make a simple ACL rule?
vampyren
I re-insalled the new version 21.08-BETA.1 and i see allot of changes. And i thought i start with the basic to setup pool , folders, user , smb.
But i cant even figure out the ACL. I have done a goup+user + shared 2 folders but i cant write to these folders.
From what i see it should have worked.
Anything i'm doing wrong?
Also for the temp folder i dont get why i had to add the mask? otherwise i could not save with only spawn user! that dont make sense, did not have to do it with backup folder!?
ps. A gui bug also, nothing major just improvement for next release. see image
Not sure if they made it the same, but you can't share as root in CORE...
vampyren
hmm and with no change it just works now o_O
Still would be helpful to know why the mask thing does. If i remove it i get this error:
