revensanchez
- Dec 17, 2019
I have an old Ubuntu VM on my system that was probably created with FreeNAS 11 (?). I hadn't fired it up in ages, but hadn't deleted it just in case I needed it for testing.
I've now upgraded the system to SCALE (TrueNAS-SCALE-22.02.4) and was cleaning up jails and tried to delete it as well. I get "[EFAULT] This system does not support virtualization." error when trying to delete through the UI. The complete traceback is below. I thought it might be a weird quirk with an old config and that something was not properly linked, so I deleted all the VMs devices, and also removed the dataset (which worked without issue), but I still get the same error.
I've searched a bunch of posts here and other articles saying that virtualization requires VTx settings in BIOS to be activated. Was this also a requirement for Core? I guess over the years I could've inadvertently changed some BIOS settings, but why does it need virtualization capability to delete a VM? Is there a way to just force the deletion from the database? With an api call maybe? Or is this a bug?
Basic specs of my setup are:
AMD Ryzen 5 3600 6-Core Processor
Asus PRIME B450M-A
Traceback:
Asus PRIME B450M-A
Traceback:
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 177, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1294, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/service.py", line 942, in delete rv = await self.middleware._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1294, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1140, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1272, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vms.py", line 395, in do_delete await self.middleware.run_in_thread(self._check_setup_connection) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1209, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1206, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 64, in _check_setup_connection self._check_connection_alive() File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 57, in _check_connection_alive self._system_supports_virtualization() File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 54, in _system_supports_virtualization raise CallError('This system does not support virtualization.') middlewared.service_exception.CallError: [EFAULT] This system does not support virtualization.
