can't auto import volume
freenasbbs
hello!
my freenas version is 9.2 and use zfs filesytem.
yesterday it had a problem and can't boot.(see http://forums.freenas.org/threads/problem-after-updating-to-9-2-0-x86.17484/). it seems there's no other solutions except re-install freenas.
so i re-install freenas 9.2 today,but i get another big problem.
after i re-install, then "storage"-- "auto import volume"--select volume name---"OK"
then i see the screen flashes quickly.(as figure)
pic_20140119_105543_136-jpg.3330
after about 4 seconds,freenas auto reboot!!
i try again but can not "auto import volume" finally.
warri
Looking in the other thread, people already warned you that you do not meet the minimum hardware requirements (ZFS needs 8 GB of RAM - or you run into problems like unimportable pools!). Upgrade your RAM and try importing again. Also I suggest you run a memtest on your current RAM to make sure it is not bad.
Also you could just downgrade to 9.1.1 again to get your data off the pool (according to your other thread, this seemed to work?).
