Any errors in the logs? What's the output of service plexmediaserver onestart if you run it in the Plex jail.
Trying to start plex from the jail ssh shows:
root@sabnzbd_1:/ # service plexmediaserver onestart
Starting plexmediaserver.
But it doesn't actually start.
Trying to start sickrage from the jail shows:
root@sabnzbd_1:/ # service sickrage onestart
Starting sickrage.
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/SickBeard.py", line 66, in <module>
	import sickbeard
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/__init__.py", line 43, in <module>
	from sickbeard.indexers import indexer_api
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/indexers/__init__.py", line 21, in <module>
	from . import indexer_api
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/indexers/indexer_api.py", line 26, in <module>
	from indexer_config import indexerConfig, initConfig
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/indexers/indexer_config.py", line 5, in <module>
	from sickbeard import helpers
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/helpers.py", line 57, in <module>
	from sickbeard import classes, db, logger
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/classes.py", line 27, in <module>
	from sickbeard.common import Quality, USER_AGENT
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/common.py", line 35, in <module>
	from fake_useragent import settings as UA_SETTINGS, UserAgent
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/fake_useragent/__init__.py", line 3, in <module>
	from fake_useragent.fake import UserAgent  # noqa
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/fake_useragent/fake.py", line 6, in <module>
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/fake_useragent/settings.py", line 8, in <module>
	DB = os.path.join(tempfile.gettempdir(), 'fake_useragent_{version}.json'.format(  # noqa
  File "/usr/pbi/sickrage-amd64/lib/python2.7/tempfile.py", line 269, in gettempdir
	tempdir = _get_default_tempdir()
  File "/usr/pbi/sickrage-amd64/lib/python2.7/tempfile.py", line 212, in _get_default_tempdir
	("No usable temporary directory found in %s" % dirlist))
IOError: [Errno 2] No usable temporary directory found in ['/tmp', '/var/tmp', '/usr/tmp', '/']
/usr/local/etc/rc.d/sickrage: WARNING: failed to start sickrage
Viewing the logs, i see this:
root@sabnzbd_1:/ # less /var/log/messages
Jun 23 04:00:00 sabnzbd_1 newsyslog[37891]: logfile turned over due to size>100K
Jun 23 04:01:00 sabnzbd_1 adjkerntz[37951]: sysctl(set: "machdep.adjkerntz"): Operation not permitted
Jun 23 04:01:00 sabnzbd_1 sendmail[37952]: v5N810Iu037952: SYSERR(root): collect: Cannot write ./dfv5N810Iu037952 (bfcommit, uid=25, gid=25): Permission denied
Jun 23 04:01:00 sabnzbd_1 sendmail[37952]: v5N810Iu037952: SYSERR(root): queueup: cannot create queue file ./qfv5N810Iu037952, euid=25, fd=-1, fp=0x0: Permission denied
Jun 23 04:31:00 sabnzbd_1 adjkerntz[38849]: sysctl(set: "machdep.adjkerntz"): Operation not permitted
Jun 23 04:31:00 sabnzbd_1 sendmail[38850]: v5N8V06W038850: SYSERR(root): collect: Cannot write ./dfv5N8V06W038850 (bfcommit, uid=25, gid=25): Permission denied
Jun 23 04:31:00 sabnzbd_1 sendmail[38850]: v5N8V06W038850: SYSERR(root): queueup: cannot create queue file ./qfv5N8V06W038850, euid=25, fd=-1, fp=0x0: Permission denied
Jun 23 05:01:00 sabnzbd_1 adjkerntz[39774]: sysctl(set: "machdep.adjkerntz"): Operation not permitted
Jun 23 05:01:00 sabnzbd_1 sendmail[39775]: v5N910uA039775: SYSERR(root): collect: Cannot write ./dfv5N910uA039775 (bfcommit, uid=25, gid=25): Permission denied
Jun 23 05:01:00 sabnzbd_1 sendmail[39775]: v5N910uA039775: SYSERR(root): queueup: cannot create queue file ./qfv5N910uA039775, euid=25, fd=-1, fp=0x0: Permission denied
Jun 23 05:31:00 sabnzbd_1 adjkerntz[40688]: sysctl(set: "machdep.adjkerntz"): Operation not permitted
Jun 23 05:31:00 sabnzbd_1 sendmail[40690]: v5N9V0Sm040690: SYSERR(root): collect: Cannot write ./dfv5N9V0Sm040690 (bfcommit, uid=25, gid=25): Permission denied
Jun 23 05:31:00 sabnzbd_1 sendmail[40690]: v5N9V0Sm040690: SYSERR(root): queueup: cannot create queue file ./qfv5N9V0Sm040690, euid=25, fd=-1, fp=0x0: Permission denied
Jun 23 07:13:57 sabnzbd_1 root: /usr/local/etc/rc.d/sickrage: WARNING: failed to start sickrage
Again, any help would be extremely appreciated... I would like to be able to get back up and running without having to lose anything or have to do a fresh reinstall...
