Mannekino
- Nov 14, 2012
I'm currently in the proces of switching over to FreeNAS 11.2 and I'm having two issues with Transmission I'm unable to solve.
Downloads folder keeps reverting back to the default settings
I've created a dataset named "Transmission" with a Downloads, Incomplete and Torrents (watch-dir) folder. I created a mount point for this dataset in the "/media" folder in the Transmission jail.
I've tried by setting the "Downloads" folder in the Transmission GUI but it doesn't save it. It keeps reverting back to the regular folder "/usr/local/etc/transmission/home/Downloads".
I also tried setting the folder in the "settings.json" file of Transmission (first shutting down Transmission then changing the configuration file) but that didn't work either.
Lastly I tried changing two files named "post_install.sh", there was a line:
And I changed it to
But that didn't work either which seems logical because the file is named "post_install.sh" but I thought I would give it a try thinking maybe it would be used somehow when starting Transmission.
UDP error when I start the Transmission plugin
When I start Transmission I see the following in the console output of FreeNAS. Any thoughts what did error means and how I can resolve it?
transmission_download_dir="/usr/local/etc/transmission/home/Downloads"
transmission_download_dir="/media/Downloads"
Oct 20 21:20:29 transmission transmission-daemon[7066]: UDP Failed to set receive buffer: No buffer space available (/wrkdirs/usr/ports/net-p2p/transmission-daemon/work/transmission-2.94/libtransmission/tr-udp.c:65) Oct 20 21:20:29 transmission transmission-daemon[7066]: UDP Failed to set receive buffer: requested 4194304, got 42080 (/wrkdirs/usr/ports/net-p2p/transmission-daemon/work/transmission-2.94/libtransmission/tr-udp.c:84)
