I have run into this issue lately where something that worked (port forwarding with PIA) now suddenly doesn't and nothing has changed in terms of OS (updates, jails). External changes that I have noticed are:
1. Verizon quantum router seems to have gotten a firmware update that now redirects to SSL secured route (certificate is self-signed)
What used to happen is for the port to close suddenly after working fine for like a week. This was either because transmission just barfed or it was actually closed by PIA. This led to me restarting the jail again. No big deal.
I have noticed things over time such as:
tun0 state DOWN emailed to me (I reviewed the logs and the state went back UP after a second)
Because things worked I didn't really look into it much.
Another thing that really fucking bothers me:
uname -KU
shows significantly different values in transmission jail. In a new jail I made to test out they were 1102500 1102000. Current jails including transmission (that I migrated) all have 1102500 1100122.
Again stuff has been working fine for months. I don't know why all of a sudden it broke. I even updated from 11.2-RELEASE.U1 to U2.1 to see if that would do anything. Nope.
Anyone have any ideas where to look. I have wasted 6 hours today to no avail. Looking if its a DNS issue didn't lead me anywhere. Checking open ports for my VPN connection ip also was fine.
I got transmission to log and this is something that comes up in logs:
Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (/wrkdirs/usr/ports/net-p2p/transmission-daemon/work/transmission-2.94/libtransmission/natpmp.c:70)
Port Forwarding State changed from "Not forwarded" to "???" (/wrkdirs/usr/ports/net-p2p/transmission-daemon/work/transmission-2.94/libtransmission/port-forwarding.c:92)
The last line bothered me so I went looking into transmission source:
port-forwarding.c
That is an absolutely fucking horrendous way to log something. So bad I might actually ditch this fucking thing. Mind you that is a log message supposed to help you figure out what's happening.
Has anyone seen this before?
I appreciate every second of your time. Thanks.
uname -KU
port-forwarding.c
