wang1zhen
- Dec 17, 2020
First-time post here, and I am really a newbie to TrueNAS with limited Unix experience and knowledge.
I've built my TrueNAS machine with 8 x 2TB used SAS Hard drives (which are cheap enough for practising).
Since the Hard drives are used, I tried to run long SMART tests on all the drives, via the webUI, and no success:
also I tried
What am I supposed to do? The short test runs fine, yet I still wish to run long SMART tests so that I would be less worried about the lifetime of the disks.
Thanks in advance.
Errors:
da0
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RC3 amd64] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org Long (extended) offline self test failed [unsupported field in scsi command]
da1
da2
da3
da4
da5
da6
da7
da0
da1
da2
da3
da4
da5
da6
da7
also I tried
sudo smartctl -t long /dev/da0smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RC3 amd64] (local build)
sudo sas2flash -listall returns:LSI Corporation SAS2 Flash Utility
Version 16.00.00.00 (2013.03.01)
Copyright (c) 2008-2013 LSI Corporation. All rights reserved
Adapter Selected is a LSI SAS: SAS2008(B2)
Num Ctlr FW Ver NVDATA x86-BIOS PCI Addr
0 SAS2008(B2) 10.00.08.00 0a.02.00.21 07.19.00.00 00:01:00:00
Finished Processing Commands Successfully.
Exiting SAS2Flash.
Exiting SAS2Flash.
Thanks in advance.
