SOLVED Cannot install - not enough space on 8GB Stick
operator
i will install the actually FreeNAS (11.2 or 11.3 - not sure, downladed in February) on my old FreeNAS Server (was offline for 6 months) and cannot. The hw configuration didn't changed but now i at the installation the messages: see screenshots
Before i was using FreeNAS 9.x and there were no problems with the stick capacity.
Patrick M. Hausen
If there is no way to get a larger stick now, download and install 11.1 and upgrade.
operator
Needs the actually version more than 8 Gigs? I didn't find something about it in the hw requirements. Just the recomended size of 16 GB or more.
Patrick M. Hausen
Most sticks labeled "8G" are actually slightly smaller. And FreeNAS is just a bit pedantic about it since 11.2.
operator
He counts 7,5 GB for the stick.
Now i tried to install the 11.1 version and get following error message - see screen below.
Patrick M. Hausen
Your install media seems to be defective. Did you burn a CD from the image or are you using a hypervisor to install? If the latter, which one? I only ever used VMware Fusion.
Patrick M. Hausen
Then your CD obviously shows "Unretryable errrors".
