I cannot get plex to start under installed plugins.
HP MicroServer - FreeNAS-9.3-STABLE-201602031011 - AMD Turion(tm) II Neo N40L Dual-Core Processor - 5990MB.
I have no other plugins running. When I try to start Plex 0.9.15.6.1714 I get a message on screen that says an error has occurred.
When I try to start Plex in the plugin jail console I get the following:
/var/log/messages
I have changed the plex IP in configuration to an un-used one on my network (192.168.1.100) and set this as a static IP on my router using the MAC address provided for plex.
I cannot access Plex configuration on my LAN http://192.168.1.100:32400/web/index.
Any further guidance would be appreciated.
After thought - I have an onboard NIC and an Intel Pro NIC installed. There is no LAN cable connected to the onboard NIC - is it possible that the plugin is trying to use the onboard NIC? If so can I configure it to use the Intel NIC? Or should I just delete the onboard NIC from my configuration?
service plexmediaserver onestart plexmediaserver already running? (pid=68994).
/var/log/messages
# more /var/log/messages Mar 3 17:44:19 plexmediaserver_1 newsyslog[59974]: logfile first created Mar 3 17:44:19 plexmediaserver_1 syslogd: kernel boot file is /boot/kernel/kern el
