Cannot create pool
bcs-srl
Hello, no disk available during pool creation (see screenshot).
gpsguy
Active Member
Please provide detailed hardware information, as well as version of FreeNAS per the forum rules in red at the top of the page.
Imagine if I said "my truck won't run" and gave you a picture of my truck. I didn't provide enough information to be helpful. .
bcs-srl
Build FreeNAS-11.2-U5 Platform Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz Memory 7825MB
In attachment other informations.
  • debug-freenas-20190629170748.tgz
gpsguy
Active Member
Please furnish this information (as text) in the body of the message. Those of us on mobile device can't easily look at a .tgz file.
  • Hard drives, quantity, model numbers, and RAID configuration, including boot drives
  • Hard disk controllers
niconico
Hello, I'm new with freenas and it seems I have the same problem on my Intel NUC NUC5CPYH
My config is
OS Version:
FreeNAS-11.2-U5
(Build Date: Jun 24, 2019 20:41)
Processor:
Intel(R) Celeron(R) CPU J3060 @ 1.60GHz (2 cores)
Memory:
8 GiB
HostName:
freenas.local
In "Storage->Disk" :
Pool : (void, nothing written)
Serial : WD-WX21A8415238
Disk SIze : (void, nothing written)
When I try to create a pool no disk is available (No data to display)
Thanks for help.
ada0 is usually your boot drive.
What disks have you connected to which controller?
You can not store any data on your boot drive and it can also not be used for plugins/jails/VMs. Boot drives are for booting (and a little system logging), nothing else.
