I'm creating a pool of SSD drives. I don't lz4 compression enabled on the pool. I know you can disable it, but I would prefer it disabled right from the start. I tried using zpool to create the pool, but then it doesn't show up in the FreeNAS GUI.
Does anyone have advice on disabling compression during creation of the pool, OR importing the pool into the GUI that was created using zpool? I've worked with zpool and zfs in Solaris, pretty new to FreeNAS.
