Hello!
I have a rather annoying problem on Truenas Scale (TrueNAS-SCALE-22.12.4.2).
When I try to create a new dataset (called test123 in this example) it fails, logs shown below.
Things I have also tried:
1) I have also tried manually but maybe it is not supposed to work? (cd /mnt/hdd_pool/; mkdir test123) It also fails with operation not permitted and I am the root user.
2) Rebooted the server.
3) Export / import the pool.
4) It is possible to create a new dataset inside an existing dataset.
Do you have any suggestions?
Thank you.
Thank you.
[EFAULT] Failed to mount dataset: cannot mount '/mnt/hdd_pool/test123': failed to create mountpoint: Operation not permitted
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 1114, in mount
dataset.mount()
File "libzfs.pyx", line 465, in libzfs.ZFS.__exit__
dataset.mount()
File "libzfs.pyx", line 3972, in libzfs.ZFSDataset.mount
libzfs.ZFSException: cannot mount '/mnt/hdd_pool/test123': failed to create mountpoint: Operation not permitted
File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 115, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 46, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 40, in _call
return methodobj(*params)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1383, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 1117, in mount
raise CallError(f'Failed to mount dataset: {e}')
middlewared.service_exception.CallError: [EFAULT] Failed to mount dataset: cannot mount '/mnt/hdd_pool/test123': failed to create mountpoint: Operation not permitted
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 184, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1317, in _call
File "/usr/lib/python3/dist-packages/middlewared/service.py", line 940, in create
rv = await self.middleware._call(
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1247, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1379, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 3470, in do_create
await self.middleware.call('zfs.dataset.mount', data['name'])
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1368, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1325, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1331, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1246, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1231, in run_in_executor
