Cancel plugin installation?
Jack Graymer
I am having troubles installing Plex. I am reading the forums and trying different settings and workarounds. The problem is that when Plex encounters an error an will fail, gets stuck at 50% for around 15 minutes, making this process of trial an error incredibly long and boring.
Is there a way to cancel a plugin installation mid way? to send a signal to cancel the process and start the process to 'Partial plugin destroyed' immediately?
Alecmascot
I suggest you give up trying to install Plex via a plugin and use a manual method.
I expect you will find help in this forum to do that.
