Can some one help me ( a noob) with setting a static address ?
Michael Mielko
In frenas 7 I was able to figure out how to set a static address to my desired IP (192.168.2.130) but having difficulty with frenas 8. Can some one walk me through the process via the GUI I am a bit confused.
audix
I am not sure, but I think you should do this via the console. There you choose 1 (Configure Network Interfaces), say "no" to dhcp and enter your desired ip address.
Tekkie
GUI -> Network -> Global Configuration -> Interfaces -> Edit (select the interface you want to change)
- un-tick DHCP
- enter IP address
audix
Tekkie, for me there are no interfaces available there. The only interface I have is the one created when I originally configured freenas (from the console). That interface is not available from the gui. Is yours?
A bug?
Tekkie
Are you saying that the interfaces screen doesn't show a single NIC?
Can you run the interface config from the console and let it do a DHCP configuration and then try again?
Michael Mielko
Thanks, works great .... just like I wanted it to ... I would of found the settings gui for this eventually I think this was missing from 8.0 but I am not sure.
