indy
- Dec 28, 2013
I got an unfriendly email today:
This is a single ssd hosting the pool with syslog and jails on it.
The ssd has been generating errors during scrubs for ages, but they were always fixable since copies=2 was set.
I always wanted to migrate the pool to a different ssd but unfortunately was too lazy to do it in time.
The drive seems to have fully failed now, but the loss of that pool is not a problem in itself.
I dont care for the contents of this pool as my data is on another.
However there are other problems:
Trying to login via ssh fails at login, the web interface still somewhat works however.
What I have done so far:
1) Checked the zpool status via the web interface shell:
2) Tried to change the syslog pool to the functional one.
Not sure if that worked out since the web interface got stuck.
2) Tried to reboot / shutdown
Nothing seems to happen after the shutdown message, I can still open up the web interface.
3) Tried to lock (the encrypted) pool with my data on it to prevent any faulty actions regarding the file system.
Nothing seems to happen again, the web interface gets stuck on the popup message
4) Tried to shutdown via the ipmi kvm console.
Again the system does not shutdown as commanded.
Additionally the console keeps throwing up the error:
I would really appreciate help with shutting down the system gracefully.
This message was generated by the smartd daemon running on: host name: freenas DNS domain: local The following warning/error was logged by the smartd daemon: Device: /dev/ada0, unable to open device Device info: STT_FTM64GX25H, S/N:P612102-MIBY-208A016, FW:1916, 64.0 GB For details see host's SYSLOG. You can also use the smartctl utility for further investigation. No additional messages about this problem will be sent.
[root@freenas ~]# zpool status tank pool: tank state: UNAVAIL status: One or more devices are faulted in response to IO failures. action: Make sure the affected devices are connected, then run 'zpool clear'. see: http://illumos.org/msg/ZFS-8000-JQ scan: scrub repaired 12K in 0h0m with 0 errors on Fri Nov 28 01:00:54 2014 config: NAME STATE READ WRITE CKSUM tank UNAVAIL 15 102 0 102399081654048 REMOVED 0 0 0 was /dev/gptid/3fd35755-a16f-11e3-bbce-002590f062ca
vm_fault: pager read error, pid ##### (tail)
