Can not enable Active Directory or LDAP
Arbiter343GS
I have filled in all information about my domain controller and it seems to connect to it because when I attach an account, it will only save if it is an existing account in the DC and has the correct password, but the enable check-box is still grayed out. What can I do to enable it?
D
dlavigne
Guest
Did you figure this out? If not, is everything working, just the checkbox is greyed out?
Arbiter343GS
Everything works, I am just not able to enable active directory because the checkbox is grayed out, and I know its is communicating with my active directory because every time I press save with an incorrect password it, it pops up with "incorrect credentials" but when I use the correct password it will save.
D
dlavigne
Guest
Do you have the latest STABLE updates applied? If so, it is worth making a bug report at bugs.freenas.org. If you do, post the issue number here.
Arbiter343GS
Ok, I got that figured out but now when I try to enable and save my active directory connection, it loads for a while than says "The service failed to restart" at the top of the page.
D
dlavigne
Guest
Did you get this sorted? If not, post the relevant errors from /var/log/messages.
JRE
Please post in the spirit of a supportive community. Instead of writing "I got that figured out", share the specific steps that you took. This lets others learn and understand.
anodos
Sambassador
The user posted that comment four years ago. If you're having issues with AD you should create a new post.
