I am running FreeNAS-9.10.2-U1 (86c7ef5) and
I have the following pool:
where da0p2 and da1p2 are both the same 16GB flash drive.
Now I want to attach the another (completely similar) 16GB flash drive to the pool via the WEBGUI.
When I try to is get the followin error:
Error: Failed to attach disk: cannot attach da2p2 to d0p2: device too small.
This is what the log shows:
What is the problem? And how can I solve it?
NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 da0p2 ONLINE 0 0 0 da1p2 ONLINE 0 0 0
Dec 4 12:22:45 theVault GEOM: da2: the primary GPT table is corrupt or invalid. Dec 4 12:22:45 theVault GEOM: da2: using the secondary instead -- recovery strongly advised. Dec 4 12:22:45 theVault notifier: 32+0 records in Dec 4 12:22:45 theVault notifier: 32+0 records out Dec 4 12:22:45 theVault notifier: 33554432 bytes transferred in 2.553235 secs (13141930 bytes/sec) Dec 4 12:22:49 theVault notifier: dd: /dev/da2: short write on character device Dec 4 12:22:49 theVault notifier: dd: /dev/da2: end of device Dec 4 12:22:49 theVault notifier: 33+0 records in Dec 4 12:22:49 theVault notifier: 32+1 records out Dec 4 12:22:49 theVault notifier: 33595392 bytes transferred in 4.321919 secs (7773258 bytes/sec) Dec 4 12:22:56 theVault ZFS: vdev state changed, pool_guid=15607185754263842137 vdev_guid=16657468669737480713 Dec 4 12:22:58 theVault manage.py: [middleware.exceptions:37] [MiddlewareError: Failed to attach disk: cannot attach da2p2 to da0p2: device is too small ] Dec 4 12:22:59 theVault manage.py: [rollbar:1265] Got unexpected status code from Rollbar api: 403 Response: { "err": 1, "message": "access token not found: caf06383cba14d5893c4f4d0a40c33a9" } Dec 4 12:22:59 theVault manage.py: [rollbar:1097] Exception while posting item ApiError(u'access token not found: caf06383cba14d5893c4f4d0a40c33a9',) Traceback (most recent call last): File "/usr/local/lib/python2.7/site-packages/rollbar/__init__.py", line 1095, in _send_payload _post_api('item/', payload, access_token=access_token) File "/usr/local/lib/python2.7/site-packages/rollbar/__init__.py", line 1138, in _post_api return _parse_response(path, SETTINGS['access_token'], payload, resp) File "/usr/local/lib/python2.7/site-packages/rollbar/__init__.py", line 1274, in _parse_response raise ApiError(json_data.get('message') or 'Unknown error') ApiError: access token not found: caf06383cba14d5893c4f4d0a40c33a9
