Can Freenas run another OS
Gottria
Built a new file server and decided to give Freenas a go instead of windows. Got 9.10 up and running without any issues so far, created a few shares and good to go. No one thing I forgot about since this is in the garage it's also my garage PC that I use to stream music from and open service manuals on when I'm working on the cars. Is there a way to run another OS from freenas, like virtually?
pirateghost
Unintelligible Geek
Get a raspberry pi. Load up any pi distro and connect via NFS or CIFS to your FreeNAS.
My preferred audio streamer is runeaudio on my pi.
...and yes, you can install VirtualBox in a jail, and run whatever OS you want inside it. But @pirateghost's idea of streaming on a Pi is probably easier and more efficient.
Gottria
Thanks guys. I like Pirates idea but I stream from pandora and google play music services. I also have several PDF manuals that I need access to while working on cars in the garage. A linux distro should work fine and I'm thinking that would be lighter than installing a windows OS.
pirateghost
Unintelligible Geek
Grab a pi with Raspbian on it then. ;)
pirateghost
Unintelligible Geek
Out of curiosity, is it fairly simple to set up a pi to network boot from the freenas server?
have a look at this project:
http://www.berryterminal.com/doku.php/berryboot
When I used it, it had the easiest option for network booting, although I didn't find the network boot a very viable option on the pi 1 when I tried it. It might be worth it on the pi 3, or even the pi 2, but I have moved on to using quality SD Cards for my OS
