I have a dozen DEC (Digital Equipment Corp.) TK50 tapes in various formats (tar, cpio, dump, dd, ??) that I've had for awhile and would really like to try and copy off the contents before the tape drives become completely extinct. Some of them are personal, and others with Ultrix, OSF1, VAX/VMS. They should all be in good condition, and only used a handful of times.
Ideally it would be great if I could send 3 or 4 at a time and you could put them in the drive as needed and I could ssh in and see what I can pull off them, or you could make a dd or tar image and I could download that, whatever is easiest. I'm in southern California if that makes a difference.
Thanks!
-- Proto
Thanks!
-- Proto
