Myriad
- Feb 13, 2018
Hey folks:
I am having persistent CAM status: Command timeout errors and I need some advice on what to do. Following advice on this forum, I have replaced the power supply, RMA'd the drives, upgraded the case to a hot swap server enclosure and I am still receiving the errors so I am thinking it's a bad motherboard/SATA controller problem now. When I installed the new case it came with new locking SATA cable so they are all replaced.
My system:
Results of smartctl -a /dev/ada3&4:
So what do you think? Should I consider replacing the board or is there a way to upgrade the SATA controller?
Rick
My system:
- SuperMicro X10sll-f with 16GB Ram
- iStarUSA D-4-B350PL-RED Steel 4U Rackmount Server Case 5xSATA Hot-Swap (great case by the way)
- Western Digital Black WDC WD5001FZWX-00A2VA0 5TB x 2
- CORSAIR CX750M V2 (2017 Edition) Power Supply
- FreeNAS-11.2-U6
Model Family: Western Digital Black
Device Model: WDC WD5001FZWX-00A2VA0
Serial Number: WD-WX31D45RF1SZ
LU WWN Device Id: 5 0014ee f01ab8828
Firmware Version: 01.01A01
User Capacity: 5,000,981,078,016 bytes [5.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Oct 12 10:26:10 2019 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: ( 90) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 553) minutes.
Conveyance self-test routine
recommended polling time: ( 6) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 100 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 184 100 021 Pre-fail Always - 9783
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 14
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 100 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 179
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 14
192 Power-Off_Retract_Count 0x0032 200 100 000 Old_age Always - 9
193 Load_Cycle_Count 0x0032 200 100 000 Old_age Always - 4
194 Temperature_Celsius 0x0022 118 112 000 Old_age Always - 34
196 Reallocated_Event_Count 0x0032 200 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 100 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 39 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 39 occurred at disk power-on lifetime: 173 hours (7 days + 5 hours)
When the command that caused the error occurred, the device was in an unknown state.
ER ST SC SN CL CH DH
40 41 08 f0 56 b5 40 Error:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
Error 38 occurred at disk power-on lifetime: 169 hours (7 days + 1 hours)
40 41 08 68 40 9f 40 Error:
Error 37 occurred at disk power-on lifetime: 169 hours (7 days + 1 hours)
40 41 08 d8 75 9d 40 Error:
Error 36 occurred at disk power-on lifetime: 124 hours (5 days + 4 hours)
40 41 18 28 b7 75 40 Error:
Error 35 occurred at disk power-on lifetime: 100 hours (4 days + 4 hours)
40 41 10 b0 4c 44 40 Error:
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Code:
Serial Number: WD-WX11DB5147N2
LU WWN Device Id: 5 0014ee f0100d7c1
Local Time is: Sat Oct 12 10:39:15 2019 EDT
was never started.
been run.
command.
power-saving mode.
recommended polling time: ( 490) minutes.
3 Spin_Up_Time 0x0027 184 100 021 Pre-fail Always - 9791
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 26
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 267
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 26
192 Power-Off_Retract_Count 0x0032 200 100 000 Old_age Always - 18
193 Load_Cycle_Count 0x0032 200 100 000 Old_age Always - 9
194 Temperature_Celsius 0x0022 119 111 000 Old_age Always - 33
ATA Error Count: 143 (device log contains only the most recent five errors)
Error 143 occurred at disk power-on lifetime: 266 hours (11 days + 2 hours)
40 41 00 c8 d7 5c 40 Error:
Error 142 occurred at disk power-on lifetime: 266 hours (11 days + 2 hours)
40 41 00 30 7e 60 40 Error:
Error 141 occurred at disk power-on lifetime: 266 hours (11 days + 2 hours)
40 41 00 c8 8a 42 40 Error:
Error 140 occurred at disk power-on lifetime: 266 hours (11 days + 2 hours)
40 41 00 d0 ff 43 40 Error:
Error 139 occurred at disk power-on lifetime: 242 hours (10 days + 2 hours)
40 41 00 58 44 ca 40 Error:
# 1 Short offline Completed without error 00% 239 -
# 2 Short offline Completed without error 00% 71 -
# 3 Extended offline Interrupted (host reset) 80% 8 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.So what do you think? Should I consider replacing the board or is there a way to upgrade the SATA controller?
Rick
