Busy drive slows down network performance
michen
Hello everyone,
I've come across the following problem: One of the drive of my zfs pool shows irregularly high activities in contrast to the rest. I made a snapshot of the condition:
As you can see, ada1 seems to be at max. load, while the others (ada0, [ada2, .. , ada12]) are pretty much at the same level. In consequence, network traffic slows down by 1:10 during file transfer. When I reboot FreeNAS, the problem is gone at first, then it reoccurs sometime during another network file transfer.
The FreeNAS version that I use is FreeNAS-11.1-U6.3, with a total capacity of ~20TB. It's running on an Intel Q9650 with 8GB of RAM, and it is connected to a GigBit LAN.
smartctl -a /dev/ada1 throws:
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N4ALNCTU
LU WWN Device Id: 5 0014ee 261d0f6c7
Firmware Version: 82.00A82
User Capacity: 3.000.592.982.016 bytes [3,00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Jan 17 13:36:38 2019 CET
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 241) Self-test routine in progress...
10% of test remaining.
data collection: (39720) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 399) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 179 179 021 Pre-fail Always - 6008
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 22
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 064 064 000 Old_age Always - 26577
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 22
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 12
193 Load_Cycle_Count 0x0032 193 193 000 Old_age Always - 23093
194 Temperature_Celsius 0x0022 123 115 000 Old_age Always - 27
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 26574 -
# 2 Short offline Interrupted (host reset) 90% 26573 -
# 3 Short offline Completed without error 00% 26467 -
# 4 Short offline Completed without error 00% 26466 -
# 5 Short offline Completed without error 00% 26465 -
# 6 Short offline Completed without error 00% 26464 -
# 7 Short offline Completed without error 00% 26463 -
# 8 Short offline Completed without error 00% 26462 -
# 9 Short offline Completed without error 00% 26461 -
#10 Short offline Completed without error 00% 26460 -
#11 Short offline Completed without error 00% 26459 -
#12 Short offline Completed without error 00% 26458 -
#13 Short offline Completed without error 00% 26457 -
#14 Short offline Completed without error 00% 26456 -
#15 Short offline Completed without error 00% 26455 -
#16 Short offline Completed without error 00% 26454 -
#17 Short offline Completed without error 00% 26453 -
#18 Short offline Completed without error 00% 26452 -
#19 Short offline Completed without error 00% 26451 -
#20 Short offline Completed without error 00% 26450 -
#21 Short offline Completed without error 00% 26449 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Any idea why this is happening?
Chris Moore
I have seen this before. That's a drive that is having trouble mechanically. If it is still in warranty, you should have it replaced.
SweetAndLow
Sweet'NASty
What is your smart test schedule? It seems very frequent.
Chris Moore
PS. Please use code tags, but without the spaces, to enclose lists like this: [ code ] [ /code ]
                    was never started.
                    command.
                    power-saving mode.
No Errors Logged
It makes it easier to read. Thanks
Chris Moore
Yes, that is a test every hour.
@michen , that is probably way too often... Once a day should be fine, that is what I do and a long test once a week
michen
I exchanged the presumably faulty drive with a new one of the same model. Just happened to have another two in stock. FreeNAS is now in the process of resilvering. I will report back as soon as this has been covered.
michen
Update, approx. 24h later: Process of resilvering taking longer than expected. I take it that writing to ada1 while all others are reading means that it hasn't finished yet...
Anyway, in the meantime I had to reboot because the server became unresponsive from outside (webinterface, ssh, smb). I made a snapshot of what I last saw on the monitor before I issued a reboot on the machine from the console.
Will keep you posted.
SweetAndLow
Sweet'NASty
Do you have jails or vm's running on this machine? Looks like you are swapping out memory.
michen
Monday Morning Update: Resilvering finished on friday evening. Drive activity seems back to normal, except that the alert is still flashing red: "Critical status. Pool is in a degraded state [...]".
I suppose after putting the drive back in, I made a mistake adding that drive to the pool. It didn't happen automatically, so I turned to the volume manager and supposedly chose a wrong option. Anyway, here's the output of zpool status:
root@aoslonas:~ # zpool status
  pool: data
state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
        the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: resilvered 1,61T in 1 days 05:28:00 with 0 errors on Fri Jan 18 19:53:35 2019
        NAME                                              STATE     READ WRITE CKSUM
        data                                              DEGRADED     0     0     0
          raidz3-0                                        DEGRADED     0     0     0
            gptid/78a8d143-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
            spare-1                                       DEGRADED     0     0     0
              9513749733849535178                         UNAVAIL      0     0     0  was /dev/gptid/79d4b769-8ed0-11e6-9f4d-001e8c745c80
              gptid/4dc08a0d-1a5b-11e9-83d6-001e8c745c80  ONLINE       0     0     0
            gptid/7b038b10-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
            gptid/7be32282-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
            gptid/7d0b8edf-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
            gptid/7e356607-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
            gptid/7f437239-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
            gptid/804e146d-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
            gptid/8159a565-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
            gptid/82613ec8-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
            gptid/836b0c26-8ed0-11e6-9f4d-001e8c745c80    ONLINE       0     0     0
        spares
          15578953262426563672                            INUSE     was /dev/gptid/4dc08a0d-1a5b-11e9-83d6-001e8c745c80
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0 days 00:02:16 with 0 errors on Fri Jan 18 03:47:16 2019
        freenas-boot                                  ONLINE       0     0     0
          gptid/c8f1958d-89ed-11e5-9527-0015609d8e50  ONLINE       0     0     0
What can I do to make "spares" part of the degraded pool?
michen
  pool: data
state: DEGRADED
        data                                              DEGRADED     0     0     0
        spares
  pool: freenas-boot
state: ONLINE
Helped myself by detaching the spare INUSE. Everything's back to normal now.
Thanks to @Chris Moore and @SweetAndLow for their input.
Cheers!
michen
