A buddy of mine wants to build a platform that will require a lot of disks. We're looking into using FreeNAS with a 24 BAY 4U case. These are likely obvious but this is our goal in order of priority:
Compatibility and Stability
Cost
Performance
The budget is pretty tight say around 7k and we plan on using standard 3TB drives. First we're doing some research to find out what we can get by with and what kind of I/O we could expect. Actual I/O requirements aren't available yet but I will have him talk to his team to get this figured out. So with that said what kind of hardware would you recommend for a 24x3TB RAID 60 setup?
Motherboard?
RAM?
RAID card?
The volume will be mounted to a head server that will run application software utilizing this device as DAS unless other configuration options are better suited.
Thanks!
Seed
Cost
Performance
Motherboard?
RAM?
RAID card?
Thanks!
Seed
