Jonathan Dell
- Sep 22, 2011
Hi, I have been asked to create a large fast storage box for my work's video team (multiple mac pros running Final Cut). They were using a drobo pro but found it slow and bad for sharing.
After doing a lot of research this is the build I am thinking of
Norco 4220 Case
Intel Xeon X3-1220 Quad Core CPU
SuperMicro MBD-X9SCL+-F Motherboard
2x Kingston 8GB (2 x 4GB)
Corsair AX650 80+ Gold PSU
HBA
2x LSI SAS3081E-R (or Intel SASUC8I) Flashed to IT
Data Drives
16x Hitachi 5K3000 2TB
in a RAIDZ2+0 setup (two 8 drive raidz2 arrays)
OS/FreeNAS Drives
2x Hitachi 5K3000 2TB in raid 1 for security
Few things I was wondering
Would going for the
LSI 9201-16i be an ok option? It seems like it (LSI SAS2008) might not be supported in FreeNAS. It would be cheaper and only 1 slot
Should I scrap the raid1 os drives for a usb flash drive for FreeNAS and an Intel 320 80GB drive as a cache?
Are there any other suggestions anyone has?
I am hoping for > 60MB/s over 2 gigabit lacp connections
They want it to be as fast or faster than there local disks (which are nothing special)
Thanks
Norco 4220 Case
HBA
Data Drives
OS/FreeNAS Drives
Would going for the
Thanks
