I built a test pc and I am glad I did. FreeNAS took me a long time (about 5 weeks) to get it up and running. Now that I am ready to build an actual server I have a few more specific questions.
My server will have 10 HDD (3x6TB, 3x3TB, 4x4TB) After looking around at prices I see it is just about the same amount of money to get a server board that has 10+ SATA ports as it does to buy a board with 2-4 SATA and then buy a PCIe addon card with the 8 port SATA.
What are the advantages / disadvantages or either path? I can see an advantage of the SATA ports failing on the PCIe card is easy to replace the card rather than the whole Motherboard. I also assume that the all-in-one option is easier on drivers. I assume PCIe board is no slower than on board SATA so that's probably not an issue. What am I not thinking about, what would be a reason to go 1 way or the other, or is is all the same.
Examples of things I am considering.
OPTION 1:
all-in-one with 10 x SATA 6.0Gb/s $260
SUPERMICRO MBD-X10SRL-F
https://www.newegg.com/Product/Product.aspx?Item=N82E16813182927
OPTION 2:
MoBo and PCIe with 6 x SATA 6.0Gb/s onboard and 4 x SATA 6.0Gb/s from PCIe $265
(taken from Chris Moore https://www.ixsystems.com/community/threads/freenas-home-build.72885/#post-504949)
System Board: Supermicro X9SRL-F Motherboard Socket LGA2011 System Board w/ I/O Shield - - US $206.99
https://www.ebay.com/itm/401678513337
Drive Controller: SAS PCI-E 3.0 HBA LSI 9207-8i P20 IT Mode for ZFS FreeNAS - - US $44.88
https://www.ebay.com/itm/192639052923
Data Drive Cables: Mini SAS to 4-SATA SFF-8087 Multi-Lane Forward Breakout Internal Cable - - US $12.99
https://www.ebay.com/itm/371681252206
I am not set hard on either setup, just looking at both. Really just want to know if I should focus more on all-in-one set up or if it doesn't really matter at all.
OPTION 1:
OPTION 2:
