noodlenoggan
- Dec 5, 2011
VirtualBox 4.3.12 on a Win7 x64 PC
FreeNAS-9.2.1.5-RELEASE-x64 (80c1d35)
BTSync Plugin 1.3.94
Hi All,
I've successfully setup FreeNAS and my Apple and Windows shares are working fine in a VirtualBox environment.
http://blog.bittorrent.com/2014/02/...-freenas-with-bittorrent-sync-using-a-plugin/
I've created another FreeNAS from scratch and followed the folder structures as instructed. I can access this FreeNAS just fine. The plugins status shows that btsync is running. According to FreeNAS (192.168.1.106), the btsync plugin is running on ip 192.168.1.250.
Unfortunately, I can't ping that IP and therefore, I can't get to its GUI web page. Do I need to create an additional interface under FreeNAS networking? Currently there is none there.
Any suggestions on what I can do to solve this?
I've redone 2 FreeNAS setups and both had the same problem.
Please help and thank you!
Hi All,
