BTsync username and password
Joshua Parker Ruehlig
is this the first time logging in? if so it's asking you to set a username and password. You don't need to set a password if you want your btsync webinterface accessible without logging in.
theaddies
It is my first time logging in but I have typed in all sorts of usernames and passwords and none are acceptable. It is a browser prompt, not a btsync prompt.
somehow a password was set on your btsync. either fresh install btsync, or edit the config after stopping btsync. in this case, for this setting your changes shouldn't get overwritten
theaddies
Where do I add the text below? There are 2 sets of "{ }" within the conf file. Do I add the text within one of them or outside of both?
"login": "admin"',
"password": "password",
"login": "admin"',
I'm not sure. There is documentation of btsync's config file available online.
But, actually I take back recommendation of editing the config file. I remembered that user/pass are by defult stored in btsync's database, and whatever is in the config just hardcodes over it. Since this is a new install I recommend reinstalling btsync.
theaddies
That worked. After reinstalling the first time I clicked "here" it opened up a page asking for username and password. Thanks for the help.
no prob =]
ericv
I had this issue today, I have no idea how I did not save the password as I use a password manager. Anyways, this is how you fix this...
1 - Stop the Resilio / BTsync Service
2 - Login to the jail
3 - Navigate to /var/db/resilio
4 - Remove the settings.dat and settings.dat.old files
5 - Restart the plugin
You will be prompted like this is a new account, however all of your sync folders will be there and not effected.
