blueberryjr
- Sep 7, 2017
I broke a plex plugin jail which seems to have broken the installed plugins tab in the web ui. It refuses to load the installed plugins list. I get a message to destroy and re-create the plugin but I can't do that since it won't load the jails. I would love to go in and edit the plugin/jail config file and just remove the entry and delete all the files manually if that is possible but I'm unable to find anything. Any help would be most appreciated.
Errors below are from trying to load the installed plugin page on the new web ui
Error: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 243, in json_load jail_dataset.properties["org.freebsd.iocage:host_hostuuid"] File "libzfs.pyx", line 2059, in libzfs.ZFSPropertyDict.__getitem__ KeyError: 'org.freebsd.iocage:host_hostuuid' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker res = loop.run_until_complete(coro) File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete return future.result() File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 372, in list_resource resource_list = iocage.list("all", plugin=True) File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1143, in list quick=quick File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_list.py", line 75, in list_datasets _all = self.list_all(ds) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_list.py", line 153, in list_all conf = iocage_lib.ioc_json.IOCJson(mountpoint).json_load() File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 258, in json_load silent=self.silent) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 80, in logit _callback(content) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 63, in callback raise RuntimeError(message) RuntimeError: plex is missing it's configuration, please destroy this jail and recreate it. """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 155, in call_method result = await self.middleware.call_method(self, message) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1033, in call_method return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 970, in _call return await self._call_worker(serviceobj, name, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 997, in _call_worker job, File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 928, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 913, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) RuntimeError: plex is missing it's configuration, please destroy this jail and recreate it.
