Hi all
After my adventures of fixing a broken plugin jail, I seem to have managed to break the default jail.
Here's the story:
I can make pluginjails no problem
I was making a default jail when my router restarted, and the jail creation process was stuck on 65%. I left it for an hour and it never progressed so I cancelled it and restart the FreeNAS box.
Since then, I cannot create default jails. Pluginjails all work OK.
I've found the "Unable to find template error" can be related to DNS so I have attempted to change DNS servers to publicly accessible ones such as Google. No luck.
I tried warden template create -nick 'NAMEOFSCREWEDUPTEMPLATE' -tar http://download.freenas.org/jails/9.3/x64/freenas-standard-9.3-RELEASE.tgz which at first failed, but then worked. But it fails to create a jail with it.
I have a feeling maybe it is screwed up permissions?
Can anyone make some suggestions about logs etc I should be looking at?
Thanks
Here's the story:
Thanks
