- Nov 25, 2013
Hi, all,
after Upgrade from 9.2 to 9.3 all Templates except this one are missing in the GUI:
VirtualBox-4.3.12
http://download.freenas.org/jails/9.2/x64/freenas-virtualbox-4.3.12.tgz
This is the output on the command line:
[root@freenas-pmh] ~# warden template list
Jail Templates:
pluginjail--x64 - FreeBSD (amd64)
Oddly enough the VirtualBox template is not listed and the pluginjail--x64 is not visible in the GUI. I have one mineos plugin jail active since 9.2 times that references the pluginjail--x64 template.
I can manually add the standard--x64 template through the GUI from this URL:
http://download.freenas.org/jails/9.3/x64/freenas-standard-9.3-RELEASE.tgz
That does not show in the warden template list output, either.
And what happened to all the other templates like Debian, Centos, etc.? I'm reluctant to upgrade the FreeNAS of a friend that I look after from time to time. He relies heavily on a Debian jail running Logitech Media Server - this Perl monster that fails to install on anything but the Linux distribution the devs seem to have used ;)
I found various threads about jails and plugins but no solution.
Thanks for any hints
Patrick
VirtualBox-4.3.12
Jail Templates:
Patrick
