I have suffered this for long now, perhaps years. I would like to finally get it solved. Why does the network bridge for iocage jails not start at boot?
I am running Version: FreeNAS-11.3-U5. I have iocage jails set to use bridge0 as net device. On every boot, the device is down.
I have googled this a lot during they years, but no help. Even similar posts appear here as solved. I bet it's got to do with order of things at boot, or perhaps I just missed something. Here are the tunables I have for rc:
Both dmesg and /var/log/messages fail to mention bridge0:
and it perfectly works if I do it manually:
This makes me mad, at every boot all jails are lost. Super unreliable system.
The MB is
Any help appreciated, thanks in advance.
cloned_interfaces bridge0 ifconfig_bridge0 addm ix0 up ifconfig_ix0 up
sudo grep 'bridge0\|ix0' /var/log/messages Oct 10 16:37:06 freeknas ix0: <Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.2.12-k> mem 0xddc00000-0xdddfffff,0xdde04000-0xdde07fff at device 0.0 on pci6 Oct 10 16:37:06 freeknas ix0: Using MSI-X interrupts with 5 vectors Oct 10 16:37:06 freeknas ix0: Ethernet address: ac:1f:6b:b1:e3:8c Oct 10 16:37:08 freeknas kernel: ix0: link state changed to UP Oct 10 16:37:08 freeknas kernel: ix0: link state changed to UP
# ifconfig bridge create ; ifconfig bridge0 addm ix0 bridge0 # ifconfig bridge0 bridge0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:63:7b:f9:ea:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 0 ifcost 0 port 0 member: ix0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 2000
The MB is
Base Board Information Manufacturer: Supermicro Product Name: A2SDi-4C-HLN4F
