It's my first try at python and it actually is a frankenstein because I got some snippets from everywhere, modified to taste. Maybe you get some value out of the error because I don't.
import json
import subprocess
import requests
USER = "root"
PASSWORD = "xxxxxxxxxxx"
DOMAIN_NAME = "xxx.xxx.x.x'"
PROTOCOL = 'https://'
r = requests.put(
PROTOCOL + DOMAIN_NAME + '/api/v1.0/system/settings/',
auth=(USER, PASSWORD),
headers={'Content-Type': 'application/json'},
data=json.dumps({
"stg_guiprotocol": "http",
if r.status_code == 200:
print ("Setting active certificate successful")
else:
print ("Error setting active certificate!")
print (r)
sys.exit(1)
Error:
File "/usr/local/lib/python3.6/site-packages/urllib3/contrib/pyopenssl.py", line 441, in wrap_socket
cnx.do_handshake()
File "/usr/local/lib/python3.6/site-packages/OpenSSL/SSL.py", line 1426, in do_handshake
self._raise_ssl_error(self._ssl, result)
File "/usr/local/lib/python3.6/site-packages/OpenSSL/SSL.py", line 1174, in _raise_ssl_error
_raise_current_error()
File "/usr/local/lib/python3.6/site-packages/OpenSSL/_util.py", line 48, in exception_from_error_queue
raise exception_type(errors)
OpenSSL.SSL.Error: [('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')]
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 326, in connect
ssl_context=context)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/ssl_.py", line 329, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/local/lib/python3.6/site-packages/urllib3/contrib/pyopenssl.py", line 448, in wrap_socket
raise ssl.SSLError('bad handshake: %r' % e)
ssl.SSLError: ("bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')],)",)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='xxx.xxx.x.xxx', port=xxxx): Max retries exceeded with url: /api/v1.0/system/settings/ (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')],)",),))
File "test.py", line 17, in <module>
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 126, in put
return request('put', url, data=data, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 502, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 634, in send
history = [resp for resp in gen] if allow_redirects else []
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 634, in <listcomp>
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 212, in resolve_redirects
**adapter_kwargs
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 612, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 504, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='xxx.xxx.x.xxx', port=xxxx): Max retries exceeded with url: /api/v1.0/system/settings/ (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')],)",),))
I tried over http as well:
cnx.do_handshake()
chunked=chunked)
conn.connect()
timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.1.250', port=4321): Max retries exceeded with url: /api/v1.0/system/settings/ (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')],)",),))
**adapter_kwargs
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='192.168.1.250', port=4321): Max retries exceeded with url: /api/v1.0/system/settings/ (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')],)",),))
