Hi everyone, I am a new User to FreeNAS and have been pulling my hair out with the following certificate issue.
My environment has a Windows 2019 PKI (Offline Root, Enterprise Subordinate).
I have followed the below steps:
The strange thing is that when you look at the cert via Chrome, all certs in the chain report as "OK".
From the FreeNAS shell I have run the command "openssl s_client -showcerts -connect <myserver>:<ssl_port>" which gives me the error: "Verify return code: 19 (self signed certificate in certificate chain)"
Some reading tells me this is the case because a RootCA is always self signed. I therefore added the RootCA to the local store by running the following command "openssl x509 -in <Crt File> -text >> /etc/ssl/cert.pem"
Now when I run the command "openssl s_client -showcerts -connect <myserver>:<ssl_port>" there are no errors. However I am still receiving the original error within Chrome.
I feel as though I am very close to cracking it. Any thoughts?
Thanks,
Rich
- Generated a CSR request via the FreeNAS web GUI (11.3-RELEASE-p7).
- Issued a Web certificate using the advanced certificate request
- Created a text file containing full chain of certificates (From top to bottom, Web cert, Sub CA, Root CA)
- Imported Certificate to FreeNAS
- Updated GUI SSL certificate to the New Cert
Thanks,
Rich
