I recently swapped my chassis from a Chenbro RM23612 to a Supermicro SC846E for more room and better thermal. However, it seems like that the backplane in the Chenbro was direct attach and Supermicro is expander type. Both ran on 3 Mini-SAS cables to my 2 M1015 in IT mode. I expected the switch to cause some problems, but after I had everything installed and plugged it, it booted up and loaded FreeNAS to my surprise. Although, I am now seeing these errors in the bootup process that I am wondering I need to be concerned and if I can do anything to get rid of them.
_mapping_get_dev_info: failed to compute the hashed SAS Address for SATA device with handle 0x000a
_mapping_get_dev_info: failed to compute the hashed SAS Address for SATA device with handle 0x000b
_mapping_get_dev_info: failed to compute the hashed SAS Address for SATA device with handle 0x000c
_mapping_get_dev_info: failed to compute the hashed SAS Address for SATA device with handle 0x0012
_mapping_get_dev_info: failed to compute the hashed SAS Address for SATA device with handle 0x0013
_mapping_get_dev_info: failed to compute the hashed SAS Address for SATA device with handle 0x0014
_mapping_get_dev_info: failed to compute the hashed SAS Address for SATA device with handle 0x0015
(probe1:mps1:0:19:5): CAM status: CCB request completed with an error
(probe1:mps1:0:19:5): Retrying command
(probe0:mps1:0:18:5): INQUIRY. CDB: 12 a0 00 00 24 00
(probe0:mps1:0:18:5): CAM status: CCB request completed with an error
(probe0:mps1:0:18:5): Retrying command
(probe2:mps1:0:20:5): INQUIRY. CDB: 12 a0 00 00 24 00
(probe2:mps1:0:20:5): CAM status: CCB request completed with an error
(probe2:mps1:0:20:5): Retrying command
(probe3:mps1:0:21:5): INQUIRY. CDB: 12 a0 00 00 24 00
(probe3:mps1:0:21:5): CAM status: CCB request completed with an error
(probe3:mps1:0:21:5): Retrying command
(probe1:mps1:0:19:5): INQUIRY. CDB: 12 a0 00 00 24 00
