Hi everybody!
I have two freenas servers, that I use for different purposes: the first contains some disks, that I use for storage and backup. On this server are configured some plugins like Owncloud, BTSync, etc. and some nfs sharings. The second server runs only some multimedia plugins, such PlexMediaServer, Sickrage, Subsonic, etc. . Because multimedia files are stored on the first server, I used the "mount -t nfs 192.168.1.46:/mnt/mediadisk /mnt" command to mount remote directories from the first server to the multimedia server, and it works perfetly. But I needed an automatic mounting on startup. So I modified the /conf/base/etc/fstab adding a line like this:
192.168.1.46:/mnt/mediadisk /mnt nfs rw 0 0
It works perfectly, but only if the first server is online. If it is powered off the media server stuck during booting on :
"[tcp] 192.168.1.46:/mnt/mediadisk: RPCPROG_NFS: RPC: Port mapper failure - RPC: Timed out"
and doesn't finish bootup.
Now I would ask you if exist a way to configure startup auto-mounting that in case of connection's fail with remote server, the local server starts normally, only without mounting remote nfs share.
Thank you for the suggestions!
