Encountering issue with installing FreeNAS v11u4 on HPE Gen 10 Microserver. I am unable to boot from USB thumb drive to implement install. I am running American Megatrends BIOS 5.12 on an AMD StoneyCPU and booting in Legacy mode.
I have used some previously reported steps to move the boot process forward partially. These include:
1) A thread originated by Rafal Lukawiecki titled “Installer hangs during boot (11.1 on AMD)”. The entry from FUNTOWNE in the thread listed adding hw.pci.realloc_bars=”1” during the loader process. This got me past the same point Rafal had encountered a hang on the same type server.
2) Changing the vfs.mountroot timeout per another post from the default 180 to 80000 also moved my boot process past the point where I was unable to complete mountroot.
I have hit another snag during boot and am wondering if anyone has an idea.
Here are the last 11 lines of output to the monitor before the system hangs:
mountroot: waiting for device /dev/msdosfs/FREENAS…
(probe:umass-sim0:0:0:0): INQUIRY. CDB: 12 00 00 00 24 00
(probe:umass-sim0:0:0:0): CAM status: CCB request completed with an error
(probe:umass-sim0:0:0:0): Retrying command
da0 at umass-sim0 bus 0 scbus 10 target 0 lun 0
da0: <Kingston DataTraveler 3.0 PMAP> Removable Direct Access SPC-4 SCSI device
da0: Serial Number 0014857749E5BE41876E215D
da0: 400.000MB/s transfers
da0: 15000MB (30720000 512 byte sectors)
da0: quirks=0x2<NO_6_BYTE>
random: unblocking device.
Here is the text of my loader.conf file:
# Boot loader file for FreeNAS
autoboot_delay="2"
loader_logo="%NANO_LABEL_LOWER%"
loader_menu_title=" "
loader_version=" "
loader_brand="%NANO_LABEL_LOWER%-brand"
vfs.root.mountfrom="cd9660:iso9660/FreeNAS"
# The following delay during mounting of root file
# system is needed because mounting of an IPMI CD-ROM
# sometimes slow.
vfs.mountroot.timeout="80000"
# Switch ZVOLs into "dev" mode, skipping GEOM.
vfs.zfs.vol.mode=2
# Disable unused GEOM labels based on disk serial number.
# Multiple providers for exactly the same disk may create confusions.
kern.geom.label.disk_ident.enable="0"
# Disable AHCI Enclosure support, not wired anywhere now.
hint.ahciem.0.disabled="1"
hint.ahciem.1.disabled="1"
# Increase dmesg buffer to fit longer boot output.
kern.msgbufsize="524288"
# Prefer newer mrsas(4) to mfi(4) for controllers supported by both.
hw.mfi.mrsas_enable="1"
# Don't wait for USB detach when rebooting. We may wish
# to investigate this further.
hw.usb.no_shutdown_wait=1
# Added for HPE Gen10 Microserver
hw.pci.realloc_bars="1"
autoboot_delay="2"
loader_version=" "
# sometimes slow.
vfs.zfs.vol.mode=2
