Sorry for the obvious noob questions and thanks in advance:
I've been running a USB3 boot drive on an internal USB3 connector (didn't think about the heat issues) with 11.1-U5 and it's been fine up until they started to turn the cooling off over the weekends and the room the server is in gets to about 100 degrees F during the day. I was able to bring it back up by moving the drive to a USB2 port on the back of the server and did a fresh save of my configuration (system --> general --> save configuration button and put it on a flash drive). Is this really the only file I need to save to get this working again from a CD/DVD?
I have this server "joined" to my domain (not sure if this is the proper term) so that I can pull Active Directory info for the shares, will I need to fool with this since the new boot with different boot drive may have a different SID? Or is the SID going to be the same and no conflicts in anything?
Planning on putting in at least 1 SSD, might do a mirrored pair of SSD for the boot drive, need to read up on the best way to mirror them (drive controller vs. some kind of software mirror).
Is there a way to "simply" add the SSD's and mirror them with the USB drive, then detach the USB drive? That would be most elegant if possible. I saw another post about duplicating the boot drive that suggested setting up a mirror through the web interface, then detaching the second (or third) drive to store off site, but I didn't completely grasp everything. there was also a link to a Solaris guide to do something similar through a shell, but again I didn't fully grasp it. Here's the thread https://forums.freenas.org/index.php?threads/backing-up-the-system-os-device.62371/#post-444697
Not that experienced with Freenas, so if anyone is willing to walk me through the process, I'd appreciate the help. Links to tutorials on making a mirrored boot environment would also be greatly appreciated. Time to go download 11.1-U5 since I don't have it on disk, I let the system download and update from 11.1-u2 (skipping U4 due to being in the middle of a semester and not wanting the student's files to disappear if there was a problem).
Hardware specs. are:
SuperMicro X10 board
Dual Xeon processors
On board SATA to 8 HGST drives (one big ZRaid2)
Samsung USB3 boot
32GB of Kingston ECC ram (approved for the main board, I think)
LACP dual 1GB links - LACP configured on the Enterasys C5 switches (works for what I need)
local keyboard, video, mouse if needed
Was working great since January when I built it.
Lower end Samsung 850 EVO SSD drives will be going in for boot because they are what I have on hand right now (most recent firmware if that matters). Last 2 open ports on the main board as well
Samsung USB3 boot
