Ok, crappy title, but here's the thing:
I've been mucking about with a RocketRAID 2720SGL controller and 4 x 3TB WD Green disks in a RAID5 configuration. As you might expect, the Green disks don't do too well in RAID5 and although I got the setup to work (eventually, gah!) I don't actually trust it now. In part because the write performance is suspiciously poor, in part because I did a rebuild which took over a week to finish, and also I've read too many warnings about Idle3 and TLER.
So I'd like to give FreeNAS a try now, and I'm wondering what's the best way to proceed. Here's what I have:
- a spare motherboard (Asrock something, I forget)
- some i5 CPU
- 16 GB of RAM
- 3 x 80 GB Intel SSDs (hoping to leverage them for caching, maybe?)
- 4 x 3 TB WD30EZRX (Green) drives
- 2720SGL RAID controller which I'm hoping to use as a straight SATA controller (it has an additional 8 ports, the motherboard only has 4)
Now I could just jump straight in, but why not try to get a few pointers before wasting my time, you know? Cause you see I have questions!! Behold:
If I use the RAID controller without setting up any arrays, any attached disks will appear (at least in Win7) as regular SATA devices. However I'm worried that the controller might still decide to drop one of the drives if an error recovery takes longer than ten seconds (as it would in RAID mode.) Would anyone know what the expected behaviour for the 2720SGL is in this case?
Would it make sense to set up a hardware RAID0 for the SSDs? And if so, say I install FreeNAS to that array, will it be able to use the unused space for caching purposes or does FreeNAS need dedicated drives for that? Or should I use a whole 80 GB drive just for FreeNAS?
Without the 2720SGL I only have the four SATA ports on the motherboard but another option would be to use those for the HDDs, ditch the 2720SGL altogether, forego caching on the SSDs and boot FreeNAS from a USB drive. Is this advisable? How would performance be in such a setup, generally speaking, and noting that I'm on gigabit ethernet so I have no use for throughput above 130 MB/s.
- some i5 CPU
- 16 GB of RAM
