I recently built my first FreeNAS server. I wished I’d had one years ago. The installation worked first time and I am getting throughput beyond my gigabit network limits. Very happy with FreeNAS!
My only disappointment was with the power consumption of my server when ‘off’. The server will remain off for most of the week so I was hoping for single digit vampire power. 28W seems too high although I initially put this down to the BMC running. After researching the BMC controller, I realised that this couldn’t be the cause. It’s only an ARM processor and LAN chipset after all.
Cutting a long story short, I ended up with only the Be Quiet BN180 PSU powered up but not connected to anything and still consuming 26W. What is more worrying is that with the PSU power switch turned off I’m still reading 14W at the wall.
(Yes I checked my meter is reading Watts and not VA. I double checked by readings against my home electricity meter. Pulling the power lead out of the PSU does correctly result in a 0W reading).
The Be Quiet website claims to have a standby drain of 0.3W. Should I be expecting to get anything near this? What is considered acceptable vampire power these days?
I can’t figure out if the PSU is faulty, poorly designed or what. Can anyone recommend a reliable PSU that is efficient when off?
Many thanks!
Many thanks!
