The parts for my new machine are on the way as discussed in this thread. After it's built, I just need to have a very basic set up. I wanted to double check my understanding to make sure I have this right in my head. The purpose of my NAS is 2 fold. 1) Very small storage area for various documents for people in my family and 2) Constant usage streaming tv shows/movies. At any given time, there are 1 - 4 people streaming at a time, although it's typically not more than 3.
I have 4 WD 2TB Red drives. I will put these in a single VDev using RAIDZ1. This will be the only VDev in my zpool. Up until now, I have kept my "Documents" and "Library" volumes separate, however, I'm not entirely sure if I can create two zpools from my single VDev. Is this possible? I will not use ZIL or L2ARC.
For my basic setup, I think this is all I will need to get up and running, correct?
The next step is, I have a 1TB NTFS USB external hard drive with all of my backed-up documents and a 3TB EXT3 USB external hard drive backup with all of my media. I assume I'll be able to attach the EXT3 drive directly to FreeNAS to copy the files over, but I'll have to connect the NTFS drive to a separate Windows machine to restore them. Is this correct? Is there some sort of utility built into FreeNAS to help move the files over, or would a straight up copy suffice?
Thanks in advance!
Thanks in advance!
