I built a server in a Fractal Node 804 case with a supermicro x11ssh-f, e3-1245v5, 64gb and 8x 4tb hdd in mirrored vdevs --and the CPU turned out to be bad. So now I'm re-thinking my initial hardware choices.
Rather than type out a long post, I'll mention that I'm trying to build a NAS that will have space for datastores for 10-15 running VMs. I own 8x 4tb HDD, a 9211-8i hba, x11ssh-f and x11scl-f motherboards and 128gb of REGISTERED (4x 32gb) memory.
I'm basically starting over and need a motherboard + CPU + memory + slog + small file/metadata drive.
Wondering if a xeon e3-1245v5 will run that? (I think CPU will be fine but the mobo might not support the devices I want)
Will the xeon e-2200 and the x11scl-f motherboard be enough? (at least the pcie slot can bifurcate and m.2 slot is x4)
or
Should I be looking at a mATX 2011-3 or lga3647 motherboards? With a 6-channel lga3647 cpu that takes nvdimm I could run CORE and use nvdimm to take care of SLOG. In a lga 3647 mATX motherboard (6 dimms) can I run the 4x 32gb RDIMM I have and then run one 32gb NVDIMM for SLOG and one Optane 128gb pmem p100 DIMM for a metadata drive space? Can you combine pmem dimms and nvidmm in the same motherboard/chipset?
Thanks for any feedback.
Budget:
I don't really care at this point. I just want to get this thing done. It is going to cost $1,500-ish either in CPU+RAM+SLOG or in motherboard + cpu + optane + NVDIMM. (on top of what I have already bought)
or
Budget:
