RegularJoe
Senior Member
- Aug 19, 2013
Hi All,
Do you know the status of plugins, i.e. what ones are added, removed, deprecated and such?
At one time in the past I could install FreeNAS 11.3 and have Bacula install, I could then add the bacula-sd and bacula-dir so that all three parts of a Bacula server would run in the jail.
Now when I go to install FreeNAS the plug in gone from the iXsystems collection and Community, I can't recall what one it was.
Is there a way to get access to the old plugins or is that a permanent change for all plugins when one is removed? Is there a change log that shows when it was removed?
FWIW I am trying to upgrade to 11.3-u5 to see if Bacula is hiding in there,
Thanks,
Joe
Thanks,
Joe
