mofarocker33
- Jul 16, 2020
Hi there Everyone,
i do want to do my Backup Server on TrueNAS, so i like Linux even when then core Version uses BSD - Who cares...
What i want ist the following thing:
I do have 4x 10TB S-ATA Drives @7200rpm (some Manufacrturere before WD took it)
also i have 4x4TB S-ata Drives @5400 (WD Red)
The Thing is, i want to make 2x Raid z1 Pools with it, but i want them to be Hot and Cold, so i can use all as one Share, but the not often changing Data goes up to the slower ones. Is that possible?
System will be an old i5-4xxx CPU an 32Gb Ram.
And Yes, causing the Main 24/7 is having 64 TB Strorage with Double Parity (Unraid) there might be added more. To not dis Calculate things.
P.s. it should be able to wake Up by WoL and then scripted to shutdown...
Thanks in Advance.
Kind regards,
Mofarocker33
Thanks in Advance.
Kind regards,
Mofarocker33
