Backup script
555NASE
Hallo, I have write my first backup script for my FreeNas.
I want to run this as a cronjob.
I have add a New Task
/bin/bash /mnt/Volume1/Medien/backup.sh
The backup.sh has the following script:
#!/bin/bash
#Variablen festlegen (immer beginnend und endend mit / )
now=$(date +"%Y_%m_%d")
source=/mnt/Volume1/Daten_Bastian
target=/mnt/Volume1/Daten_Bastian/aaaaaa
#Kopiervorgang
cp -a $source $target/$now.backup
Now when I start the Script on Console I get the following Error:
The Path "mnt\Volume1\Daten_Bastian" are not exist.
Can anyone help me?
IceBoosteR
When I am looking at the output, is says that /mnt/Volume/Daten_Bastian does not exist. In your little script you want to copy to
So, ist vol1 correct? If the path may not be correct try it with "/mnt/path..." do stick it a string-defined variable.
You can also try to open a new shell, propably just writing bash or ksh whatever, enter the varibles manually, then execute the script manually, that is easy debugging. Or set "set -x" after calling the bash, so the bash will show you everything it is doing so you can debug. More you can read here.
