FreeNAS-9.10.2-U6
I have inherited a production FreeNAS systems that need upgrading. It was running some older version of 9.10 We upgraded it to the latest 9.10, but the attempt to upgrade it to 11.1 ended badly and we rolled it back to 9.10.2-U6.
I am going to attempt the upgrade again, and as I am anticipating it to go poorly again, my plan B is to do a clean install of 11.1-U7 and restore from backup. The problem is that I believe the zpool to be encrypted, which leads me to ask two questions:
- How do I confirm whether the zpool is encrypted?
- If it is encrypted, how do I prepare myself to import the pool after a clean install of FreeNAS 11.1?
# geli status
Name Status Components
da2p1.eli ACTIVE da2p1
da3p1.eli ACTIVE da3p1
da13p1.eli ACTIVE da13p1
da55p1.eli ACTIVE da55p1
da6p1.eli ACTIVE da6p1
da7p1.eli ACTIVE da7p1
da8p1.eli ACTIVE da8p1
da9p1.eli ACTIVE da9p1
da10p1.eli ACTIVE da10p1
da11p1.eli ACTIVE da11p1
da12p1.eli ACTIVE da12p1
da4p1.eli ACTIVE da4p1
da50p1.eli ACTIVE da50p1
da15p1.eli ACTIVE da15p1
da58p1.eli ACTIVE da58p1
da17p1.eli ACTIVE da17p1
da21p1.eli ACTIVE da21p1
da22p1.eli ACTIVE da22p1
da23p1.eli ACTIVE da23p1
da24p1.eli ACTIVE da24p1
da25p1.eli ACTIVE da25p1
da26p1.eli ACTIVE da26p1
da27p1.eli ACTIVE da27p1
da28p1.eli ACTIVE da28p1
da35p1.eli ACTIVE da35p1
da36p1.eli ACTIVE da36p1
da37p1.eli ACTIVE da37p1
da5p1.eli ACTIVE da5p1
da39p1.eli ACTIVE da39p1
da40p1.eli ACTIVE da40p1
da45p1.eli ACTIVE da45p1
da46p1.eli ACTIVE da46p1
da47p1.eli ACTIVE da47p1
da48p1.eli ACTIVE da48p1
da49p1.eli ACTIVE da49p1
da38p1.eli ACTIVE da38p1
da51p1.eli ACTIVE da51p1
da52p1.eli ACTIVE da52p1
da53p1.eli ACTIVE da53p1
da34p1.eli ACTIVE da34p1
da14p1.eli ACTIVE da14p1
da18p1.eli ACTIVE da18p1
da19p1.eli ACTIVE da19p1
da20p1.eli ACTIVE da20p1
da56p1.eli ACTIVE da56p1
da29p1.eli ACTIVE da29p1
da30p1.eli ACTIVE da30p1
da33p1.eli ACTIVE da33p1
da41p1.eli ACTIVE da41p1
da42p1.eli ACTIVE da42p1
da43p1.eli ACTIVE da43p1
da44p1.eli ACTIVE da44p1
da59p1.eli ACTIVE da59p1
da16p1.eli ACTIVE da16p1
da57p1.eli ACTIVE da57p1
da60p1.eli ACTIVE da60p1
da61p1.eli ACTIVE da61p1
da62p1.eli ACTIVE da62p1
da63p1.eli ACTIVE da63p1
da64p1.eli ACTIVE da64p1
da65p1.eli ACTIVE da65p1
da66p1.eli ACTIVE da66p1
da67p1.eli ACTIVE da67p1
da68p1.eli ACTIVE da68p1
da31p1.eli ACTIVE da31p1
da54p1.eli ACTIVE da54p1
