LIGISTX
- Apr 12, 2015
I recently updated to TrueNAS 12 from 11.3 U3 I believe, and I am experiencing an issue with 1 of my 3 B2 backup jobs. It is failing and I am getting:
Any ideas what this could be? Quick googleling suggest turning off the replication task; it is already off. Any ideas?
Error: Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run await self.future File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 397, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/cloud_sync.py", line 1058, in sync await self._sync(cloud_sync, options, job) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/cloud_sync.py", line 1105, in _sync await rclone(self.middleware, job, cloud_sync, options["dry_run"]) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/cloud_sync.py", line 234, in rclone raise ValueError(message) ValueError: rclone failed with exit code 1
