Avahi Daemon Errors
Momos
Since a few versions back I see a lot of avahi errors in the log.
Aug  8 08:28:59 truenas 1 2021-08-08T08:28:59.515550+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:28:59 truenas 1 2021-08-08T08:28:59.515563+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:28:59 truenas 1 2021-08-08T08:28:59.515571+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:30:29 truenas 1 2021-08-08T08:30:29.524879+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:30:29 truenas 1 2021-08-08T08:30:29.524901+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:30:29 truenas 1 2021-08-08T08:30:29.524906+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:30:29 truenas 1 2021-08-08T08:30:29.524912+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:31:59 truenas 1 2021-08-08T08:31:59.532252+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:31:59 truenas 1 2021-08-08T08:31:59.532271+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:31:59 truenas 1 2021-08-08T08:31:59.532276+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:31:59 truenas 1 2021-08-08T08:31:59.532285+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:33:29 truenas 1 2021-08-08T08:33:29.604612+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:33:29 truenas 1 2021-08-08T08:33:29.604632+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:33:29 truenas 1 2021-08-08T08:33:29.604637+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:33:29 truenas 1 2021-08-08T08:33:29.604643+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:34:59 truenas 1 2021-08-08T08:34:59.612409+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:34:59 truenas 1 2021-08-08T08:34:59.612429+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:34:59 truenas 1 2021-08-08T08:34:59.612433+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:34:59 truenas 1 2021-08-08T08:34:59.612440+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:36:29 truenas 1 2021-08-08T08:36:29.619699+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:36:29 truenas 1 2021-08-08T08:36:29.619720+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:36:29 truenas 1 2021-08-08T08:36:29.619724+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:36:29 truenas 1 2021-08-08T08:36:29.619731+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:37:59 truenas 1 2021-08-08T08:37:59.627718+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:37:59 truenas 1 2021-08-08T08:37:59.627739+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:37:59 truenas 1 2021-08-08T08:37:59.627744+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:37:59 truenas 1 2021-08-08T08:37:59.627752+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:39:29 truenas 1 2021-08-08T08:39:29.634460+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:39:29 truenas 1 2021-08-08T08:39:29.634482+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:39:29 truenas 1 2021-08-08T08:39:29.634486+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:39:29 truenas 1 2021-08-08T08:39:29.634494+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:40:59 truenas 1 2021-08-08T08:40:59.642313+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:40:59 truenas 1 2021-08-08T08:40:59.642334+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:40:59 truenas 1 2021-08-08T08:40:59.642338+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:40:59 truenas 1 2021-08-08T08:40:59.642345+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:42:29 truenas 1 2021-08-08T08:42:29.649249+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 08:42:29 truenas 1 2021-08-08T08:42:29.649270+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:42:29 truenas 1 2021-08-08T08:42:29.649274+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 08:42:29 truenas 1 2021-08-08T08:42:29.649283+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 09:12:29 truenas 1 2021-08-08T09:12:29.686897+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 09:12:29 truenas 1 2021-08-08T09:12:29.686918+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 09:12:29 truenas 1 2021-08-08T09:12:29.686922+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 09:12:29 truenas 1 2021-08-08T09:12:29.686929+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 09:42:29 truenas 1 2021-08-08T09:42:29.631484+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._nfs._tcp.local    IN    SRV 0 0 2049 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Aug  8 09:42:29 truenas 1 2021-08-08T09:42:29.631506+03:00 truenas.local avahi-daemon 1510 - - Record [_smb._tcp.local    IN    PTR truenas._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 09:42:29 truenas 1 2021-08-08T09:42:29.631510+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Aug  8 09:42:29 truenas 1 2021-08-08T09:42:29.631517+03:00 truenas.local avahi-daemon 1510 - - Record [truenas._smb._tcp.local    IN    SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Being a beginner i have no idea what might cause them and how to make them stop. Tried tthe search of course but all i could find were some refferences to IPv6. I think i have disabled IPv6 in all my jails but the errors keep showing up.
I do not have much experience with the system so please go easy on me. I solved some issues in the past by reading this forum, for which I would like to thank everyone :smile:
My system is:
TrueNAS-12.0-U5
Processor: Intel(R) Core(TM) i5-10600T CPU @ 2.40GHz
Motherboard: AsRock B560 Steel Legend
RAM: 32 GB Cirsair Vengeance LPX Black CL14
Boot Pool: Mirror OCZ Vertex3 NVME & Adata SwordFish SSD
Storage: 6 x Samsung SSD EVO 860 2TB configured as 3 separate Mirrors.
Can someone point me in the right direction please ?
Thank you.
vorchan
Hello! I also get these error messages but I haven't found a solution yet either. Please does anyone know of a fix, or at least a reason?
Momos
We must be the only 2 people that have this issue :tongue:
golfleep
I just started have the exact same errors. Running 12.0-U4. I haven't found a solution yet either!
Momos
Please someone help :)
trinxie
I have the same problem! Noticed the errors some days ago. Upgraded to latest 12.0-U5.1, no difference.
Birra606
I'm Having similar issues with avahi-daemon error but different code "1339" any help muchly appreciated.
TrueNas 12.2-Release-P9
Sep 19 08:27:18 truenas 1 2021-09-19T08:27:18.254216+08:00 truenas.home.local avahi-daemon 1339 - - Record [truenas._smb._tcp.local IN SRV 0 0 445 truenas.local ; ttl=120] not fitting in legacy unicast packet, dropping. Sep 19 08:27:18 truenas 1 2021-09-19T08:27:18.275887+08:00 truenas.home.local avahi-daemon 1339 - - Record [_http._tcp.local IN PTR truenas._http._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping
trinxie
I currently have code "1387":
Sep 19 18:34:02 nas 1 2021-09-19T18:34:02.902810+02:00 nas.localdomain avahi-daemon 1387 - - Record [_middleware-ssl._tcp.local    IN    PTR nas._middleware-ssl._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Sep 19 18:34:02 nas 1 2021-09-19T18:34:02.902813+02:00 nas.localdomain avahi-daemon 1387 - - Record [nas._middleware-ssl._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Sep 19 18:34:02 nas 1 2021-09-19T18:34:02.902834+02:00 nas.localdomain avahi-daemon 1387 - - Record [nas._middleware-ssl._tcp.local    IN    SRV 0 0 443 nas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Sep 19 18:34:02 nas 1 2021-09-19T18:34:02.906684+02:00 nas.localdomain avahi-daemon 1387 - - Record [_sftp-ssh._tcp.local    IN    PTR nas._sftp-ssh._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Sep 19 18:34:02 nas 1 2021-09-19T18:34:02.906699+02:00 nas.localdomain avahi-daemon 1387 - - Record [nas._sftp-ssh._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Sep 19 18:34:02 nas 1 2021-09-19T18:34:02.906721+02:00 nas.localdomain avahi-daemon 1387 - - Record [nas._sftp-ssh._tcp.local    IN    SRV 0 0 22 nas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Sep 19 18:34:02 nas 1 2021-09-19T18:34:02.906731+02:00 nas.localdomain avahi-daemon 1387 - - Record [_ssh._tcp.local    IN    PTR nas._ssh._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Sep 19 18:34:02 nas 1 2021-09-19T18:34:02.906735+02:00 nas.localdomain avahi-daemon 1387 - - Record [nas._ssh._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Sep 19 18:34:02 nas 1 2021-09-19T18:34:02.906742+02:00 nas.localdomain avahi-daemon 1387 - - Record [nas._ssh._tcp.local    IN    SRV 0 0 22 nas.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Momos
I do not think the error code has anything to do with the problem. Mine shows now 1474.
The log is full of these errors.
I spent many many hours trying to find an answer to this one , no success.
alwu
i've been seeing similar errors too. i'm running truenas 12.0-u5.
Oct  2 00:05:30 holocron 1 2021-10-02T00:05:30.941296-07:00 holocron.local avahi-daemon 1481 - - Record [holocron._ssh._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Oct  2 00:05:30 holocron 1 2021-10-02T00:05:30.941303-07:00 holocron.local avahi-daemon 1481 - - Record [holocron._ssh._tcp.local    IN    SRV 0 0 22 holocron.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Oct  2 00:07:00 holocron 1 2021-10-02T00:07:00.952872-07:00 holocron.local avahi-daemon 1481 - - Record [_sftp-ssh._tcp.local    IN    PTR holocron._sftp-ssh._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Oct  2 00:07:00 holocron 1 2021-10-02T00:07:00.952888-07:00 holocron.local avahi-daemon 1481 - - Record [holocron._sftp-ssh._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Oct  2 00:07:00 holocron 1 2021-10-02T00:07:00.952897-07:00 holocron.local avahi-daemon 1481 - - Record [holocron._sftp-ssh._tcp.local    IN    SRV 0 0 22 holocron.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Oct  2 00:07:00 holocron 1 2021-10-02T00:07:00.952911-07:00 holocron.local avahi-daemon 1481 - - Record [_smb._tcp.local    IN    PTR holocron._smb._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Oct  2 00:07:00 holocron 1 2021-10-02T00:07:00.952915-07:00 holocron.local avahi-daemon 1481 - - Record [holocron._smb._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Oct  2 00:07:00 holocron 1 2021-10-02T00:07:00.952923-07:00 holocron.local avahi-daemon 1481 - - Record [holocron._smb._tcp.local    IN    SRV 0 0 445 holocron.local ; ttl=120] not fitting in legacy unicast packet, dropping.
Oct  2 00:07:00 holocron 1 2021-10-02T00:07:00.952938-07:00 holocron.local avahi-daemon 1481 - - Record [_ssh._tcp.local    IN    PTR holocron._ssh._tcp.local ; ttl=4500] not fitting in legacy unicast packet, dropping.
Oct  2 00:07:00 holocron 1 2021-10-02T00:07:00.952942-07:00 holocron.local avahi-daemon 1481 - - Record [holocron._ssh._tcp.local    IN    TXT  ; ttl=4500] not fitting in legacy unicast packet, dropping.
Oct  2 00:07:00 holocron 1 2021-10-02T00:07:00.952950-07:00 holocron.local avahi-daemon 1481 - - Record [holocron._ssh._tcp.local    IN    SRV 0 0 22 holocron.local ; ttl=120] not fitting in legacy unicast packet, dropping.
jgreco
Resident Grinch
The numbers you guys are quoting appears to be the process ID.
emk2203
Just chiming in and resurrecting this old thread to remind that this is still an issue. I would be happy to have a workaround, even when the Avahi guys don't fix the problem. The log pollution is annoying when you look for some real issues.
Is the only solution switching off Avahi?
From the Github discussion @jgreco mentioned, there seems to be a temporary fix with
publish-addresses=yes
publish-hinfo=no
publish-workstation=no
publish-domain=no
publish-resolv-conf-dns-servers=no
publish-aaaa-on-ipv4=no
publish-a-on-ipv6=no
but where do I put it in the TrueNAS system?
trinxie
Looking forward to solve this as well :smile:
Momos
Same !
