I have set up a local replication task using the GUI. It has generated snapshot tasks which seem to be running correctly.
The problem is, while the replication tasks are created, they get stuck at the RUNNING status with 0% progress for hours. This is on a small disk. I am not able to start new tasks because I get the error [EFAULT] Task is already running.
The tasks seem to work when started manually, but not automatically.
Is there a workaround that I can use to at least clear the old tasks so I can try to run new ones?
Thank you.
Thank you.
