Authorized_Key vanishes...
herger
hi all!!
I am new for this forum.
I have many issues with FreeNAS. I am not using the GUI, I am using it through ssh.
1) I need to access without putting the password. I have created the
id_rsa.pub file on the source computer and appended it through cat in my FreeNAS server.
The problem is that this is the third id_rsa.pub file that I append and it is always erase automatically from the system after few minutes...
It seems that only two authorized keys can be handled: is it true??
2) If I start a rsync process in remote, via ssh, I see that this process lasts for maximum 20 minutes, then it is reset...
I have already changed the
/etc/ssh/ssh_config file in the following way:
ServerAliveCountMax 700
ServerAliveInterval 100
ClientAliveInterval 120
ClientAliveCountMax 720
UseRoaming no
but nothing changes... It seems like a timeout problem, as the log file says
rsync error: unexplained error (code 255) at rsync.c(551) [sender=3.0.9]
but I cannot fix it...
Can anyone help, please?
Thanks and regards
H
D
dlavigne
Guest
For configuration purposes, you have to use the GUI as that is the only way your changes are saved to the configuration database. Anything you do from the command line is not saved.
Spearfoot
He of the long foot
Welcome to the forums!
Please post your full system specifications per the Forum Rules.
Are you logging in as root or as another user? If you're logging in as root, you will need to configure the SSH service in the GUI to allow 'Login as root with password' and in any case you should enable 'Allow password authentication' just long enough to log in once and let the system add your workstation to the known_hosts. You've probably already done this. You can change these settings later, once everything is working.
There are no limits on the number of keys you can store in ~/.ssh/authorized_keys. Make sure this file has permission settings of 0600. I have no idea why this file would 'disappear'...
I've never had to modify the /etc/ssh/ssh_config settings, so you probably ought to restore that file to its original values. Chances are that your changes will be overwritten during the next FreeNAS upgrade anyway.
Good luck!
herger
Hi all!
Thanks.
I have used the GUI to paste the id_rsa.pub key and checked that the permissione of .ssh/authorized_keys are set to 600.
The problema permain:
- the aithorized key (the third in the file) is lost;
- the rsync process via ssh stops after a couple of hours: I have to sync 1.7 Tb of files, I have synced 470 Gb....
Do You have clues?? :( :( :(
Thanks and regards
H
Spearfoot
He of the long foot
Again, please post your full system specifications per the Forum Rules. Also, please describe exactly what you're trying to do, and how you're trying to do it.
It's very difficult for us to help you if you don't give us as much information as possible.
Do you have two FreeNAS servers? If so, which one is the source and which one the target? On which FreeNAS server are you initiating the rsync transfer?
Or are you trying to synchronize two pools on the same FreeNAS server?
What user account are you using? If you're not using root, is it possible that the user's home directory (and therefore the user's authorized_keys file) is being over-written during the transfer?
SweetAndLow
Sweet'NASty
What version of freenas? Sounds like a bug if the key doesn't get set.
